Probleme mit script 1.02
kosmar3212
Beitrag von kosmar3212 »
Creating pihole ...
Creating traefik ...
Creating portainer ...
Creating nextcloud_db ... done
Creating ei23 ...
Creating vscode ...
Creating bitwarden ...
Creating mosquitto ...
Creating homeassistant ... done
Creating esphome ... done
Creating influxdb ...
Creating nextcloud ...
ERROR: for pihole UnixHTTPConnectionPool(host='localhost', port=None): Read tim ed out. (read timeout=60)
ERROR: for influxdb UnixHTTPConnectionPool(host='localhost', port=None): Read t imed out. (read timeout=60)
ERROR: for vscode UnixHTTPConnectionPool(host='localhost', port=None): Read tim ed out. (read timeout=60)
ERROR: for traefik UnixHTTPConnectionPool(host='localhost', port=None): Read ti med out. (read timeout=60)
ERROR: for mosquitto UnixHTTPConnectionPool(host='localhost', port=None): Read timed out. (read timeout=60)
ERROR: for bitwarden UnixHTTPConnectionPool(host='localhost', port=None): Read timed out. (read timeout=60)
ERROR: for ei23 UnixHTTPConnectionPool(host='localhost', port=None): Read timed out. (read timeout=60)
ERROR: for portainer UnixHTTPConnectionPool(host='localhost', port=None): Read Creating nextcloud ... done
ERROR: for portainer UnixHTTPConnectionPool(host='localhost', port=None): Read timed out. (read timeout=60)
ERROR: An HTTP request took too long to complete. Retry with --verbose to obtain debug information.
If you encounter this issue regularly because of slow network conditions, consid er setting COMPOSE_HTTP_TIMEOUT to a higher value (current value: 60).
Ist dies eine Erstinstallation, müssen mit dem ei23 Skript nochmals Passwörter g esetzt werden
Den Wust an Fehlermeldung bekomme ich auf dem Bildschirm angezeigt. Ich benutze einen RPI4 - 2GB mit 32 GB Usb Stick.
Kann mir einer von Euch weiterhelfen?
Sublime0391
Re: Probleme mit script 1.02
Beitrag von Sublime0391 »
Hallo ,
versuche es mal so :
COMPOSE_HTTP_TIMEOUT=200 docker-compose up -d
Kann ich nicht reproduzieren...
